Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: epics php
From: Christophe Moins <christophe.moins@ego-gw.it>
To: tech-talk@aps.anl.gov
Date: Mon, 19 Jun 2006 12:02:26 +0200
Hello,
we run a php script using the epics php module with the command line tool under gdb on a Redhat 9.0-3 machine with kernel 2.4.20-9.
A segmentation fault shows up periodically and here is what we get with the bt command under gdb :
#0 0xffffe002 in ?? () #1 0x402d984e in epicsEventWait (pevent=0x0) at ../../../src/libCom/osi/os/posix/osdEvent.c:75 #2 0x402d3d3e in epicsEvent::wait() (this=0xfffffffc) at ../../../src/libCom/osi/epicsEvent.cpp:63 #3 0x40322dfd in tcpSendThread::run() (this=0x81e6d30) at ../tcpiiu.cpp:85 #4 0x402d2118 in epicsThreadCallEntryPoint (pPvt=0x81e6d34) at ../../../src/libCom/osi/epicsThread.cpp:59 #5 0x402d8e2f in start_routine (arg=0x81ecd28) at ../../../src/libCom/osi/os/posix/osdThread.c:301 #6 0x400222b6 in start_thread () from /lib/tls/libpthread.so.0
It seems that there is a problem with the thread primitives but we did not manage to know what was going on.
Do you have any idea ?
Thanks
Christophe
RE: epics php Jeff Hill
Prev: RE: STAT -> SCAN Walters, M (Malcolm)
Next: How to kill an IOC from a Client Steven Banks
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Next: RE: epics php Jeff Hill
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
