Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Problem using waveforms with caget and camonitor
From: "Walters, M \(Malcolm\)" <M.Walters@diamond.ac.uk>
To: "TECHTALK Tech-Talk" <tech-talk@aps.anl.gov>
Date: Tue, 6 Jun 2006 17:23:23 +0100
I've just encountered a problem with both the command-line caget and
camonitor when you try to read waveforms in conjunction with other data.
If you try to read a single value followed by a waveform then you only
get the first point of the waveform. Similarly if you try to read a
shorter waveform followed by a longer waveform then you only get part of
the longer waveform.
Both of these are to do with how the maximum size is determined. To fix
these I have altered how these function calculate this size. If a
specified number of points is requested (using -# N) then that becomes
the maximum returned. Otherwise the whole array is read back always.
I hope this doesn't break any expected behaviour. The patches are
attached.
Malcolm
Malcolm Walters
01235 778557
Diamond Light Source Ltd.
Rutherford Appleton Laboratory,
Chilton, Didcot, Oxfordshire OX11 0QX
Malcolm.Walters@diamond.ac.uk
Attachment: caget.patch
Description: caget.patch
Attachment: camonitor.patch
Description: camonitor.patch
Re: Problem using waveforms with caget and camonitor Ralph Lange
Prev: php library Christophe Moins
Next: Re: Problem using waveforms with caget and camonitor Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
