Title: Re: Motor.h file broken for C
Excellent, thanks Ron!
-doug
On 6/5/06 11:02 AM, "Ronald L. Sluiter" <[email protected]> had this to say:
Hello Doug,
In that case, we are way ahead... OK, we are a couple of months
ahead of you. Mark Rivers removed the C++ comments and
added a typedef to the motor_cmnd enumeration several months
ago. I released these changes with version R5-9 of the motor
record distribution on 04/25/06; so you should not have to make
these local modifications with R5-9 and above.
Hope this helps,
Ron
Doug Murray wrote:
> Hi Ron, I should have been more specific.
> We’re using the GNU cross-compiler (for RTEMS) v4.0.2, but we use the
> –ansi (and –Wall) flags, which will make a difference.
> Also, we’ve got version 1.14 of motor.h. The line containing
> #define LSB_First (TRUE) // ...
> Is not giving us a problem, probably because cpp is getting at it
> before the compiler.
> Our errors come from some previous lines in the file (lines 117 and
> 118) which are:
> // Define, from top to bottom, how bit fields are packed.
> // This works for VxWorks, SunPro, Linux g++, MS Visual C.
> I just added /* ... */ comments.
> The typedef problem becomes an issue around line 188, in the following
> declaration within motor_dset:
> RTN_STATUS (*build_trans) (motor_cmnd, double *, struct motorRecord *);
> I changed this by adding ‘enum’:
> RTN_STATUS (*build_trans) ( enum motor_cmnd, double *, struct
> motorRecord *);
> These changes should be okay with any C or C++ compiler, regardless of
> ANSI flags.
> Thanks!
> -doug
> On 6/2/06 2:21 PM, "Ronald L. Sluiter" <[email protected]> had this to say:
> Hello Doug,
> What compiler are you using?
> I compiled the latest distribution of the motor record (R5-9) using
> five different compilers without a problem.
> I presume you mean these C++ comments in motor.h;
> "LSB_First (TRUE) // LSB is packed first."
> I have changed these to C comments and committed the changes
> into CVS. They will appear in the next release.
> Could you be more specific as to the "missing typedef" problem?
> I don't see that.
> Best regards,
> Ron
> Doug Murray wrote:
>> Hi Ron, the motor.h include file (we’re using 3.14.8.2) seems to be
>> written for inclusion in C++ files. Specifically, there are a couple
>> of ‘//’ comments and a missing typedef for an enum. Can you change
>> this file to accommodate both C and C++?
>> -doug
>> Doug Murray
>> Stanford Linear Accelerator Center
>> LCLS Controls Department
>> 2575 Sand Hill Road
>> Menlo Park, CA 94025 MS-102
- Re: Motor.h file broken for C Ronald L. Sluiter
CA overload 32 * 9 waveforms etc. Emmanuel Mayssat
<2006>
Solution to install MCA on Windows Gan Quan
<2006>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
