Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: Motor.h file broken for C
To: "Ronald L. Sluiter" <sluiter@aps.anl.gov>
Cc: TechTalk EPICS <tech-talk@aps.anl.gov>
Date: Mon, 05 Jun 2006 10:07:15 -0700
Title: Re: Motor.h file broken for C
Hi Ron, I should have been more specific.
We’re using the GNU cross-compiler (for RTEMS) v4.0.2, but we use the –ansi (and –Wall) flags, which will make a difference.
Also, we’ve got version 1.14 of motor.h.   The line containing
   #define LSB_First (TRUE)  // ...
Is not giving us a problem, probably because cpp is getting at it before the compiler.
Our errors come from some previous lines in the file (lines 117 and 118) which are:
   // Define, from top to bottom, how bit fields are packed.
   // This works for VxWorks, SunPro, Linux g++, MS Visual C.
I just added /* ... */ comments.
The typedef problem becomes an issue around line 188, in the following declaration within motor_dset:
   RTN_STATUS (*build_trans) (motor_cmnd, double *, struct motorRecord *);
I changed this by adding ‘enum’:
   RTN_STATUS (*build_trans) ( enum motor_cmnd, double *, struct motorRecord *);
These changes should be okay with any C or C++ compiler, regardless of ANSI flags.
Thanks!
-doug
On 6/2/06 2:21 PM, "Ronald L. Sluiter" <sluiter@aps.anl.gov> had this to say:
Hello Doug,
What compiler are you using?
I compiled the latest distribution of the motor record (R5-9) using
five different compilers without a problem.
I presume you mean these C++ comments in motor.h;
"LSB_First (TRUE) // LSB is packed first."
I have changed these to C comments and committed the changes
into CVS. They will appear in the next release.
Could you be more specific as to the "missing typedef" problem?
I don't see that.
Best regards,
Ron
Doug Murray wrote:
> Hi Ron, the motor.h include file (we’re using 3.14.8.2) seems to be
> written for inclusion in C++ files. Specifically, there are a couple
> of ‘//’ comments and a missing typedef for an enum. Can you change
> this file to accommodate both C and C++?
> -doug
> Doug Murray
> Stanford Linear Accelerator Center
> LCLS Controls Department
> 2575 Sand Hill Road
> Menlo Park, CA 94025 MS-102
Re: Motor.h file broken for C Ronald L. Sluiter
Prev: Re: Scaling a waveform record Tim Mooney
Next: Re: Motor.h file broken for C Ronald L. Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Prev: Re: Motor.h file broken for C Ronald L. Sluiter
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
