What compiler are you using? I compiled the latest distribution of the motor record (R5-9) using five different compilers without a problem. I presume you mean these C++ comments in motor.h; "LSB_First (TRUE) // LSB is packed first." I have changed these to C comments and committed the changes into CVS. They will appear in the next release. Could you be more specific as to the "missing typedef" problem? I don't see that. Best regards, Ron Doug Murray wrote: Hi Ron, the motor.h include file (we’re using 3.14.8.2) seems to be written for inclusion in C++ files. Specifically, there are a couple of ‘//’ comments and a missing typedef for an enum. Can you change this file to accommodate both C and C++?
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
