attached is a test program that can reproduce the problem. Since it uses sysClkRateGet(), it compiles only on vxWorks. It calls pasynOctet->readRaw() once with pasynUser->timeout=1.1/sysClkRateGet() and once with pasynUser->timeout=1.0/sysClkRateGet(). In the first case, readRaw() returns asynTimeout, as expected. In the second case, readRaw() does not return. I print the thread ID before calling readRaw(). When I do 'tt' on the thread ID, readRaw() suddenly returns asynTimeout. Very strange. A Makefile is also attached. No records are required. Just set up a TCP server somewhere, call drvAsynIPPortConfigure and run: readTimeoutTest "portname". BTW: As long as readRaw() hangs, I could not open a channel access connection to records on that IOC and the dbior command hangs when trying to report drvAsyn. I use asynDriver version 4-5, EPICS base R3.14.8, vxWorks 5.5 on MVME2300 (ppc604). Dirk Dirk Zimoch wrote: Hi Marty, Jeff et al
#include <asynDriver.h> #include <asynOctet.h> #include <epicsThread.h> #include <sysLib.h> static char* asynStatusStr[] = {"Success", "Timeout", "Overflow", "Error"}; void readTimeoutTestHandleRequest(asynUser* pasynUser) { asynInterface* pasynInterface; asynOctet* pasynOctet; void* pvtOctet; char buffer[1]; asynStatus status; size_t received; int eomReason; printf ("readTimeoutTestHandleRequest, thread = %s %p\n", epicsThreadGetNameSelf(), epicsThreadGetIdSelf()); pasynInterface = pasynUser->userPvt; pasynOctet = pasynInterface->pinterface; pvtOctet = pasynInterface->drvPvt; pasynUser->timeout = 1.1 / sysClkRateGet(); printf ("calling pasynOctet->readRaw() with %g seconds timeout\n", pasynUser->timeout); status = pasynOctet->readRaw(pvtOctet, pasynUser, buffer, 1, &received, &eomReason); printf ("pasynOctet->readRaw() returned status %s\n", asynStatusStr[status]); pasynUser->timeout = 1.0 / sysClkRateGet(); printf ("calling pasynOctet->readRaw() with %g seconds timeout\n", pasynUser->timeout); status = pasynOctet->readRaw(pvtOctet, pasynUser, buffer, 1, &received, &eomReason); printf ("pasynOctet->readRaw() returned status %s\n", asynStatusStr[status]); } void readTimeoutTestTimeout(asynUser* pasynUser) { printf ("pasynManager->queueRequest() timed out\n"); } int readTimeoutTest(char * port, int addr) { asynStatus status; asynUser* pasynUser; asynInterface* pasynInterface; pasynUser = pasynManager->createAsynUser(readTimeoutTestHandleRequest, readTimeoutTestTimeout); if (pasynManager->connectDevice(pasynUser, port, addr) != asynSuccess) { printf ("No such device: %s,%d\n", port, addr); return ERROR; } pasynInterface = pasynManager->findInterface(pasynUser, asynOctetType, TRUE); if (!pasynInterface) { printf ("No asynOctet interface: %s,%d\n", port, addr); return ERROR; } pasynUser->userPvt = pasynInterface; status = pasynManager->queueRequest(pasynUser, asynQueuePriorityHigh, 10.0); if (status != asynSuccess) { printf ("pasynManager->queueRequest() failed: %s\n", pasynUser->errorMessage); return ERROR; } return OK; } TOP=../.. include $(TOP)/configure/CONFIG HOST_OPT = NO PROD_vxWorks = asynApp DBD = asynApp.dbd asynApp_DBD += base.dbd PROD_SRCS += asynApp_registerRecordDeviceDriver.cpp PROD_SRCS += readTimeoutTest.c asynApp_DBD += drvAsynIPPort.dbd PROD_LIBS += asyn PROD_LIBS += $(EPICS_BASE_IOC_LIBS) include $(TOP)/configure/RULES
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
