Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: bringing up EPICS 3.14.8.2 on VxWorks for a Xilinx VirtexII FPGA with a PPC405 core
To: "'Chris Timossi'" <catimossi@lbl.gov>
Cc: "'TECHTALK'" <tech-talk@aps.anl.gov>
Date: Tue, 30 May 2006 14:58:51 -0600
Hello Chris,
Referring to Mantis 259:
The first question to ask is what might be different between this and a more
conventional PPC. Is it a site specific vxWorks BSP?
It says "Exception current instruction address". Do we know what type of
exception it is (this presumably can be decoded from the machine status
register value)? Could it be a floating point exception? Are the floating
point registers saved by ISR that use floating point?
Does this happen only if CA clients are connected?
You might also try the following:
O Use the "i" command to see if any of the TCBs (task control blocks) are
corrupted and or if any other threads are suspended (in a failed state).
O Use the memShow command to detect corrupted pool.
Jeff
__________________________________________________________
Jeffrey O. Hill               Mail         JOHill@lanl.gov
LANL MS H820                  Voice        505 665 1831
Los Alamos NM 87545 USA       Fax          505 665 5107
Prev: Acces I/O 104-AIO16-16E A/D Card Jon Brinkmann
Next: Re: Building a standalone IOC for an Intel embedded system David Kline
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Next: about building ChannelArchiver for base3.14 Zhao Zhuo
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
