I don't currently have a build environment for mca, so could someone
else please handle this?
Carl
zhaozhuo wrote:
> Hi, Carl,
> I'm compiling mca in base-3.14.7, the operating system is RedHat Linux
> WS4(kernel is 2.6.9-22), the host-arch linux-x86 and target-arch is
> linux-x86, GCC 3.4.4, GNU Make 3.80, matlab 6.5, when I make according
> to the "README" file , there are some error like the following:
> [epics@localhost mca]$ make
> mex -v -I/home/epics/epics3.14.7/base-3.14.7/include
> -I/home/epics/epics3.14.7/b ase-3.14.7/include/os/Linux -DEPICS_DLL_NO
> -L/home/epics/epics3.14.7/base-3.14.7 /lib/linux-x86 -ldbStaticHost
> -lCom -lca mca.cpp MCAError.cpp Channel.cpp Channe lAccess.cpp -o
> O.linux-x86/mca.mexglx
> -> mexopts.sh sourced from directory (DIR = .)
> FILE = /home/epics/epics3.14.7/extensions/src/mca/mexopts.sh
> -> MATLAB = /home/epics/matlab
> -> CC = gcc
> -> CC flags:
> CFLAGS = -fPIC -ansi -D_GNU_SOURCE -pthread -DGCC
> CDEBUGFLAGS = -g
> COPTIMFLAGS = -O -DNDEBUG
> CLIBS = -Wl,--rpath-link,/home/epics/matlab/extern/lib/gln
> x86,--rpath-link,/home/epics/matlab/bin/glnx86
> -L/home/epics/matlab/bin/glnx86 - lmx -lmex -lmat -lm -lm
> arguments = -DEPICS_DLL_NO
> -> CXX = gcc
> -> CXX flags:
> CXXFLAGS = -fPIC -ansi -D_GNU_SOURCE -DGCC -pthread -I$EPICS_
> BASE/include -I$EPICS_BASE/include/os/Linux
> CXXDEBUGFLAGS = -g
> CXXOPTIMFLAGS = -O -DNDEBUG
> CXXLIBS = -Wl,--rpath-link,/home/epics/matlab/extern/lib/gln
> -L/ade/epics/supTop/base/R3.14.2/lib/linux-x86 -lca -lCom -l readline
> -lcurses -losp -lrt -lm
> -> FC =
> -> FC flags:
> FFLAGS =
> FDEBUGFLAGS =
> FOPTIMFLAGS =
> FLIBS =
> -> LD = gcc
> -> Link flags:
> LDFLAGS = -pthread -shared -Wl,--version-script,/home/epics/
> matlab/extern/lib/glnx86/mexFunction.map
> LDDEBUGFLAGS = -g
> LDOPTIMFLAGS = -O
> LDEXTENSION = .mexglx
> arguments = -L/home/epics/epics3.14.7/base-3.14.7/lib/linux-x 86
> -ldbStaticHost -lCom -lca
> -> LDCXX =
> -> Link flags:
> LDCXXFLAGS =
> LDCXXDEBUGFLAGS =
> LDCXXOPTIMFLAGS =
> LDCXXEXTENSION =
> -> gcc -c -I/home/epics/epics3.14.7/base-3.14.7/include
> -I/home/epics/epics3.14 .7/base-3.14.7/include/os/Linux
> -I/home/epics/matlab/extern/include -DMATLAB_MEX _FILE -fPIC -ansi
> -D_GNU_SOURCE -DGCC -pthread -I$EPICS_BASE/include -I$EPICS_BA
> SE/include/os/Linux -DEPICS_DLL_NO -O -DNDEBUG mca.cpp
> In file included from mca.cpp:23:
> queue.h: In member function `Node<T>* Node<T>::GetPrev() const':
> queue.h:84: error: `Prev' undeclared (first use this function)
> queue.h:84: error: (Each undeclared identifier is reported only once
> for each fu nction it appears in.)
> queue.h: In member function `int Queue<T>::Size() const':
> queue.h:123: error: there are no arguments to `Empty' that depend on a
> template parameter, so a declaration of `Empty' must be available
> queue.h:123: error: (if you use `-fpermissive', G++ will accept your
> code, but a llowing the use of an undeclared name is deprecated)
> queue.h:129: error: `count' undeclared (first use this function)
> mex: compile of 'mca.cpp' failed.
> make: *** [O.linux-x86/mca.mexglx] Error 1
> Could you help me find the reason? Thank you very much!
> Zhao Zhuo
> Accelerator Control Group,
> Accelerator Research Center
> Institute of High Energy Physics (IHEP)
> P.O. Box 918-10
> Beijing, 100049
> P.R. China
> Tel: +86-10-88236268-11 or 88236269-11 (O)
> Fax: +86-10-88236190
> E_mail: [email protected] <mailto:[email protected]>
Carl Lionberger
Control System Software Engineer
Berkeley National Laboratory (LBNL)
(510)486 7503
- from ihep in china zhaozhuo
Re: asynDriver / epicsTimer bug Eric Norum
RE: asynDriver / epicsTimer bug Jeff Hill
<2006>
almost deleted message unread, was: Re: from ihep in china Maren Purves
FFTW for vxWorks? Eric Norum
<2006>
