I am using currently the php module to display value on a web browser. The program reads first the content of a file to get the whole list of process variables and afterwards performs a ca_get for each of them to know their value. Times to times, the browser tries to download the page with all the values, but does not succeed and I have got a message saying "the document contains no data" although some data should be available. The listing of the php script is the following : <html> <body> <meta http-equiv="refresh" content="60" /> <?php #interface with Epics Iocs to know the values # of variables stored in the data file associated to the unit #load external module dl("php_epics.so"); $unitName = $_GET["unit"]; $fileName = $_GET["fileName"]; echo "<h1>VALUES OF ".$unitName."</h1>"; #file parsing to get the variable names list include 'GetList.php'; $variableIdent = array("record","sensor","ai","bi"); $variableList = GetList($fileName,$variableIdent); $nbVar = count($variableList); for ($index=0; $index < $nbVar; $index++) { $variableName = $variableList[$index]; $variableValue = ca_get($variableName); echo "$variableName $variableValue <BR>"; } ?> </body> </html> And the GetList function is the following one : <?php #file parsing to get the variable names list stored in fileName function GetList($fileName,$variableIdent) { $file=fopen($fileName,"r"); #$variableNumber = 0; $variableList = ""; $index = 0; while(! feof($file)) { $line = fgets($file); $variableName = strstr($line,$variableIdent[0]); if ($variableName != FALSE && (strstr($line,$variableIdent[1]) != FALSE || strstr($line,$variableIdent[2]) != FALSE || strstr($line,$variableIdent[3]) != FALSE )) { $rawName = strstr($line,"\""); $variableName = strtok($rawName, "\""); $variableList[$index] = $variableName; $index++; } } fclose($file); return $variableList; } ?> Has Anyone ever met such a problem ? Thanks Christophe
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
