Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: bug in break-point table conversion
To: "D. Peter Siddons" <siddons@bnl.gov>
Cc: Rolf Keitel <rolf@triumf.ca>, tech_talk <tech-talk@aps.anl.gov>
Date: Mon, 15 May 2006 17:53:38 -0500
D. Peter Siddons wrote:
I had also just run into this. It is also a bug in the makeBpt program to generate a table from raw data. It produces nonsense if the raw ADC values are in decreasing order and the engineering values are increasing. I didn't try it with positive slope but reversed data order. I thought that simply reversing the table order fixed it, but apparently not.
Rolf Keitel wrote:
There is a problem with break-point table conversion from engineering to raw values ( function cvtEngToRawBpt in file cvtBpt.c).
The function returns incorrect results, if the breakpoint table has negative slopes, i.e. if engineering values decrease with increasing raw values.
I couldn't find anything in the documentation when I looked briefly the other day, but I don't think the present breakpoint table code was ever supposed to work with negative slopes. Given the limitations of the existing code though it really ought to check its inputs properly and refuse to load a breakpoint table that slopes downwards.
Any replacement code that permits negative slopes should reject curves that are not continuously increasing or decreasing but have local minima or maxima - I have no idea what the existing code does with such curves, but I doubt that it's pretty. We would also like to be able to reload breakpoint tables at runtime (which I believe Benjamin Fransken implemented for BESSY but this isn't available in the official release).
Any offers to do a proper re-engineering of this (fairly self-contained) area of functionality in EPICS Base? If no-one offers I'll try to put in the positive slope test, but if a site needs more than that it'll have to donate some effort towards implementing it.
- Andrew
There is no S in exprexxo.
Re: bug in break-point table conversion Rolf Keitel
Re: bug in break-point table conversion Benjamin Franksen
Re: bug in break-point table conversion D. Peter Siddons
Prev: Re: bug in break-point table conversion D. Peter Siddons
Next: Re: bug in break-point table conversion Rolf Keitel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
