On May 5, 2006, at 12:10 PM, John Dobbins wrote: It turn out that if I sit at the console I get the correct focus behavior. This is with Scientific Linux 3 or 4. Exceed also works for remote access. For me the problem appears to be limited to using CYGWIN for remote access. By default, cygwin uses Windows' internal window manager, which creates a Windows window for each top-level X window. Therefore, one option is to enable "focus stealing" in Windows, which should be doable using Windows PowerTools (specifically Tweak UI): http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx The second option, which we have tested, is to tell cygwin to use an alternative window manager, such as twm, fvwm2, or mwm. I hope someone finds this helpful, Devin ------ Devin Bougie Laboratory for Elementary-Particle Physics [email protected]
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
