Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: How to crash an EPICS ioc on Intel/VxWorks
To: Jane Richards <richards@triumf.ca>
Cc: tech-talk <tech-talk@aps.anl.gov>
Date: Fri, 12 May 2006 10:32:15 -0500
Hi Jane,
Jane Richards wrote:
A channel access client (we have used dm, edm and caget) which asks for a PV that is composed of a valid record name and an (invalid) field name of greater than 19 characters crashes the CA_UDP task. A buffer overflow occurs in the dbStaticLib.c function dbFindField.
Our Motorola MV162s do not crash.
We have identified the offending code as follows (MAX_FIELD_NAME_LENGTH is defined as 20):
Bug acknowledged and confirmed, although I can't reproduce the crash here because I don't have a vxWorks-pentium system and this doesn't kill a linux-x86 IOC.
This is Mantis bug #256.
I'd like to get rid of MAX_FIELD_NAME_LENGTH completely from dbStaticLib.c, but for now the fix that I'm committing is to increase the size allocated for the fieldName[] array by 1.
- Andrew
There is no S in exprexxo.
How to crash an EPICS ioc on Intel/VxWorks Jane Richards
Prev: How to crash an EPICS ioc on Intel/VxWorks Jane Richards
Next: Naming Conventions and Control Logix John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
