<snip> from a web browser, I have the following display : Well the error message you're getting says "I can't load the php_epics.so library because it in turn needs to load libCom.so which I can't find." Run 'ldd /usr/local/lib/php/extensions/php_epics.so' to find out where it's trying to get libCom.so from - it's part of EPICS Base so should be installed in your base/lib/<host-arch> directory, but if you didn't compile that php_epics.so file on the web server machine then it might not be present. In this case you should be able to fix it by copying libCom.so to the /usr/local/lib/php/extensions directory (you may also need libca.so in there as well). - Andrew -- There is no S in exprexxo.
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
