g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013
Subject: Artificial Intelligence (AI) / intelligent control in the accelerator control room
To: <tech-talk@aps.anl.gov>
Date: Wed, 3 May 2006 10:48:07 -0600
All,
I did a literature research on AI in accelerator control systems.
Now, I'm looking for some direct feedback from the accelerator controls
community on what kind of AI/intelligent control is or was in use to aid
accelerator control or accelerator operations (scope year 2000 - today).
In general, I consider as part of AI/intelligent control anything that
uses (but not limited to)
.	Neural network control
.	Bayesian control
.	Fuzzy (logic) control
.	Neuro-fuzzy control
.	Expert Systems
.	Genetic control
.	Intelligent agents (Cognitive/Conscious control)
... this in turn could be used for things like
.	beam tuning
.	fault recovery and/or fault detection
.	preventive maintenance
So my questions are:
	Are you using (or have you used in the past) AI/intelligent
      control in one or the other form in your control room?
		If so, what is your experience with your AI application?
		If not, do you see any benefit of using an application
		in the three areas mentioned above?
Thanks for your input,
Martin
                 (o -)
--------------oOO-(_)-OOo-------------------------------------------
 Martin Pieck              |     *           *               *   \\
 MS H820, LANSCE-IC,       | *        *        /\   *            =))
 Los Alamos National Lab   |   * /\        *  /  \    /\  /\     //
 Los Alamos, NM 87545, USA |/\  /  \/\      _/    \/\/  \/  \ *
                           |  \/      \  /\/              o  \   *
 (505) 665-0086 office     |           \/     __o       </\_  \   /\
 (505) 665-5107 fax        |     /\o_         \<      __/\     \_/
____________________________________________________________________
Prev: RE: EPICs repeater, beacon,address list, and server port Jeff Hill
Next: ISAC-II beam Rolf Keitel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
