1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Floating point exception running ArchiveEngine
To: tech talk <[email protected]>
Date: Tue, 02 May 2006 10:43:11 -0400
Hi:
That's a new one.
Run without arguments, the engine should print a usage message\ about the expected/allowed command-line arguments and quit.
Might be some compilation or LD_LIBRARY_PATH error.
Can you run the engine in a debugger?
E.g.
cd ...../extensions/src/ChannelArchiver/Engine
gdb O.linux-x86/ArchiveEngine
> run
.. and email me the results?
-Kay
On May 2, 2006, at 10:21 , Michele Joyce wrote:
We have the new version of the ChannelArchiver installed on Linux. I'm trying to get the ArchiveEngine running,but _immediately_ get a "float exception" (with or without any arguments passed to the program) I know that I'm probably missing something simple. Anyone have any ideas?
Thanks
Floating point exception running ArchiveEngine Michele Joyce
Prev: Floating point exception running ArchiveEngine Michele Joyce
Next: RE: Sequencer intro needed ! Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: EPICs repeater, beacon,address list, and server port Emmanuel Mayssat
