Hi Nino,
I think the problem is simple. Here is the syntax of the icbConfig
command:
#icbConfig(portName, module, ethernetAddress, icbAddress, moduleType)
# portName to give to this asyn port
# ethernetAddress - Ethernet address of module, low order 16 bits
# icbAddress - rotary switch setting inside ICB module
# moduleType
# 0 = ADC
# 1 = Amplifier
# 2 = HVPS
# 3 = TCA
# 4 = DSP
So your command should be
icbConfig("icbTca1", 0x98c, 1, 3)
not
icbConfig("icbTca1", 0x98c, 1, 1)
> -----Original Message-----
> From: Antonino Miceli [mailto:[email protected]]
> Sent: Friday, April 28, 2006 2:01 PM
> To: [email protected]
> Subject: asyn and Canberra TCA 2016
> Hi,
> I am running EPICS R3.14.7 on a MVME2700.
> I am configuring Canberra's AIM MCA modules. Having issues with
> the TCA module.
> icbConfig seems to be fine:
> value = 0 = 0x0
> dbLoadRecords("$(MCA)/mcaApp/Db/icb_tca.db",
> "P=dp3:,TCA=tca1,MCA=aim_adc1,PORT=icbTca1")
> value = 0 = 0x0
> But I get the following errors:
> 2006/04/28 11:11:17.728 drvIcbAsyn::drvUserCreate, unknown command=HI1
> dp3:tca1SCA1_HI devAsynFloat64::initCommon drvUserCreate
> command=LOW1
> dp3:tca1SCA1_LOW devAsynFloat64::initCommon drvUserCreate
> 2006/04/28 11:11:17.728 drvIcbAsyn::drvUserCreate, unknown command=HI2
> dp3:tca1SCA2_HI devAsynFloat64::initCommon drvUserCreate
> etc...
> Any hints on what this might be?
> Cheers,
> Nino
SNS reaches CD4 milestone!! Gurd, David P.
Re: asyn and Canberra TCA 2016 Tim Mooney
<2006>
<2006>
