This worked to resolve the symbols and I can now load the munch file (see below). At one point I headed down that path but I missed a couple underscores! ;-) However... iocInit() is throwing something. I did a task trace on the offender, but think it's related to the sntpc stuff in vxWorks. I thought I fixed this by adding #define INCLUDE_SNTPC to my vxWorks build? I'll check to make sure the ppc and (if I can find a board) the 68k can load with your new munch patch. I can see that the symbols are resolved when greping for libCom as before.
------------------------- ld < test.munch value = -2137823744 = 0x80936600 ... iocInit() ############################################################################ ### EPICS IOC CORE built on Apr 20 2006 ### EPICS R3.14.6GEM9.1 $Tag$ $Date: 2005/06/14 15:56:15 $ ############################################################################ FPE Exception Exception Program Counter: 0x808e15dc Status Register: 0x30006701 Cause Register: 0x0000003c Task: 0x80ac6fd0 "timerQueue" Starting iocInit value = 0 = 0x0 iocInit: All initialization complete Done executing startup script /home/mrippa/install/example1/bin/vxWorks-mips/testWfg -> tt "timerQueue" 80024434 vxTaskEntry +c : epicsThreadSleepQuantum (&epicsThreadCallEntryPoint, 80accebc, 0, 0) 808e141c epicsThreadSleepQuantum+78 : epicsThreadCallEntryPoint (eeeeeeee, eeeeeeee, eeeeeeee, eeeeeeee) 808d94d8 epicsThreadCallEntryPoint+a8 : timerQueueActive::run(void) (eeeeeeee, eeeeeeee, eeeeeeee, eeeeeeee) 808e78e4 timerQueueActive::run(void)+40 : epicsEvent::wait(double) (8090e180, 80ac6fd0, 80accebc, &epicsThreadCallEntryPoint) 808dba98 epicsEvent::wait(double)+40 : epicsEventWaitWithTimeout (eeeeeeee, eeeeeeee, 8008c66c, eeeeeeee) value = 0 = 0x0 -> -> -> -> iocClockSyncWithNTPserver: sntpcTimeGet S_sntpcLib_TIMEOUT Andrew Johnson wrote: Hi Matt,
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
