Hi John:
We had the case of a simple medm display using all (or most of) of a Linux
CPU. Running top showed that X-windows was using over 90% of the machine.
It turned out we were reading in analog voltages quickly and we did not
have a "minimum change before update" set in our records (I forget the
mnemonic) so we were getting display updates at the full scan rate.
Craig
On Tue, 25 Apr
2006, John Dobbins wrote:
Dear All,
We've begun using StripTool and notice that is sometimes appears to bog down
the computer on which it is running, i.e. the mouse responds haltingly with
StripTool running, there is lag in button responses,...
This is true even if StripTool is the only app running. Host is Linux.
It seems to be made worse by making the StripTool graph display larger and
helped by reducing the screen update rate.
Do others have this experience? I looked in the docs and searched Tech-Talk
but didn't see anything along these lines. Is something that can be done to
improve responsiveness?
John Dobbins
Laboratory for Elementary Particle Physics
Cornell University
Ithaca, NY
Craig Walther Joint Astronomy Centre
[email protected] 660 N. A'ohoku Place
Ph: (808) 969-6556 Hilo, HI 96720
Fx: (808) 961-6516
- StripTool bogs down host? John Dobbins
Re: drvAscii decode string Maren Purves
Re: No more CA connections? R3.14.7, 3.14.8.2, CAJ Kay-Uwe Kasemir
<2006>
Re: StripTool bogs down host? Chris Payne
<2006>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
