Tim Mooney wrote:
Ian A Smith wrote:
I'm trying to read the following into an ascii analogin record:
"=V913 1.13e-04;59;11;0;0"
and to extract the 1.13e-04 or whatever. Using <%5k%f> just times
out and so does <=V913%f>. Using %e makes no difference. If I read
the value into a stringin record, there is no problem apart from the
fact that it's a string.
Any suggestions?
If you don't find a format string that will work, you could just grab the
whole string and parse it with an sCalcout record, using the above format.
(See
http://www.aps.anl.gov/aod/bcda/synApps/calc/R2-4/sCalcoutRecord.html.)
or use a genSub - which is what I tend to do in cases where you need
only a part of the string, or split a string into more than one part.
Aloha,
Maren
- drvAscii decode string Ian A Smith
- Re: drvAscii decode string Tim Mooney
RE: No more CA connections on different IOC Jeff Hill
Re: StripTool bogs down host? Craig Walther
<2006>
Re: drvAscii decode string Dirk Zimoch
<2006>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
