1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Undefined symbols R3.14.6
To: Matt Rippa <[email protected]>
Cc: [email protected]
Date: Thu, 20 Apr 2006 20:35:12 -0400
On Thu, 2006-04-20 at 14:07 -1000, Matt Rippa wrote:
> Hi Ernest,
> Yes. Note we have an image in use for a 3.13.4 release of
> the app. Just in case, I built a new test image as
> described. I've even included the line in my makefile (but
> honestly thought that was for iocsh to work on non-vxworks
> targets ???).
You are right but it also registers record/device/driver support.
> Anyway, I get the exact same error (save the sntpc line). Am
> I wrong in thinking you can build and load acctst.c as
> described?
So, there is probably something else going on?
I did the following since acctst is already built from EPICS BASE:
# Do ca regression test from the IOC as well.
# acctst <channel name>  <interest level>
test_OBJS_vxWorks += $(EPICS_BASE_BIN)/acctst
The above worked fine for me.
I would next run the basic getting started "bare-bones" IOC described
in the App Dev Guide and look for those errors again.
Ernest
> Thanks again for any help.
> -Matt
> Ernest L. Williams Jr. wrote:
> > Hi Matt,
> > Have you already followed the recommendations at the URL listed below?
> > http://www.aps.anl.gov/epics/base/T20xConfig.html
> > Also, in your Makefile I think you need:
> > test_SRCS+= test_registerRecordDeviceDriver.cpp
> > Thanks,
> > Ernest
> > On Thu, 2006-04-20 at 09:26 -1000, Matt Rippa wrote:
> >>Hi,
> >>Migrating a channel access app to R3.14.6 on vxWorks-mips
> >>using tornado2.0. This builds okay but loading the munch
> >>file results in:
> >>ld < test.munch
> >>Undefined symbol: sntpcTimeGet (binding 1 type 0)
> >>Undefined symbol: __GLOBAL_$I$.._netiiu.cpp (binding 1 type 0)
> >>Undefined symbol:
> >>__GLOBAL_$I$.._.._.._src_libCom_cxxTemplates_epicsSingletonMutex.cpp
> >>(binding 1 type 0)
> >>Undefined symbol: __GLOBAL_$I$.._comBuf.cpp (binding 1 type 0)
> >>value = -2131312736 = 0x80f6bfa0
> >>I suspect the vxworks build is missing things and (in fact)
> >>I've found an sntpc boot-image that gets rid of the first
> >>error. Any hints on the other?
> >>I've stripped my app away completley and am just trying to
> >>load the ca regression test from base:
> >>$EPICS/base/src/ca/acctst.c
> >>Here's my Makefile:
> >>TOP=../../../../..
> >>include $(TOP)/configure/CONFIG
> >>PROD_IOC_vxWorks += test
> >>DBD += test.dbd
> >>test_DBD += base.dbd
> >>test_SRCS += acctst.c
> >>test_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
> >>test_LIBS += $(EPICS_BASE_IOC_LIBS)
> >>include $(TOP)/configure/RULES
> >>Thanks!
> >>Matt Rippa
Undefined symbols R3.14.6 Matt Rippa
Re: Undefined symbols R3.14.6 Ernest L. Williams Jr.
Re: Undefined symbols R3.14.6 Matt Rippa
Prev: Re: Undefined symbols R3.14.6 Matt Rippa
Next: RE: Undefined symbols R3.14.6 Thompson, David H.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
