Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: AlarmHandler - filtering vs. HYST
To: Brian McAllister <mcallister@mit.edu>
Cc: tech-talk@aps.anl.gov
Date: Fri, 14 Apr 2006 10:58:16 -1000 (HST)
On Fri, 14 Apr 2006, Brian McAllister wrote:
[ minor rant follows ]
I also believe that alarm limits, especially MINOR alarms, should be
influenced by operational reality as well as engineering design.  If the
normal value of an analog input is close enough to an alarm limit to
generate alarms when no action is actually required, that limit should
probably be changed.
Based on personal experience I can state that any significant number of
"nuisance" alarms will lead to users becoming less reactive to real alarms.
We were having enough issues with operators silencing ALH "forever" (so
they wouldn't be annoyed by "false" alarms) that I modified ALH to put a
black border around the button on the screen so you could tell it was
silenced without opening the alarm window.
Brian,
while I agree in principle, here follows another one of Maren's
"it depends" posts:
We have some alarm handlers that are run up "silenced forever".
In fact, most of ours are. All we want from them is an email
notification that something bad has happened.
We do occasionally have alarms that recover by themselves
without the alarm limit being anywhere near normal operational
limits: we do sometimes have powerouts here. The IOCs and
equipment continue running on their UPS(s) whereas the
compressor/chillers hat keep the instruments cold trip.
Some of them will come back on when the power does and the
instruments will cool back down by themselves, some of them
need resetting. Needless to say, it isn't always possible,
e.g. in a snowstorm, to get to the equipment to reset it
(in which case we of course also don't care whether the
alarm handler beeps as there won't be anybody in the dome).
We need to know there's a problem so that we can at least
monitor it remotely, or more often, do something about it.
- We have in one case of a non-EPICS 'hovering' alarm
(wind speed) made the alarm limit settable by the operator.
If they have already closed the dome they don't need the
beeping, but before they close the frequency of gusts
above the alarm limit will have some influence on what they
do with it. -
Aloha,
Maren
Re: AlarmHandler - filtering vs. HYST Brian McAllister
Prev: Re: AlarmHandler - filtering vs. HYST Steve Lewis
Next: Re: AlarmHandler - filtering vs. HYST Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
