Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: AlarmHandler - filtering vs. HYST
To: "Brian McAllister" <mcallister@mit.edu>
Cc: Terry Carlino <carlino@jlab.org>, tech-talk@aps.anl.gov
Date: Fri, 14 Apr 2006 12:44:56 -0700
At 3:03 PM -0400 2006/04/14, Brian McAllister wrote:
> Steve Lewis wrote: >> Try this (one of the best features of ALH): use >> $ALARMCOUNTFILTER count seconds
This will help you, but (IMO) the best solution for any alarm hovering
around a transition value is almost always to set HYST appropriately in the
record.
...snip...
I did not mean to imply HYST=0. In fact, I always set it appropriately for electronic noise and digitization artifacts. The filter is most useful for occasional, random excursions. And, yes, NOACKT is usually the right choice for these types of signals.
Based on personal experience I can state that any significant number of
"nuisance" alarms will lead to users becoming less reactive to real alarms.
We were having enough issues with operators silencing ALH "forever" (so
they wouldn't be annoyed by "false" alarms) that I modified ALH to put a
black border around the button on the screen so you could tell it was
silenced without opening the alarm window.
Agreed: sufficient false positives will always result in defeat of the system. I like your visual fix as well.
Re: AlarmHandler - filtering vs. HYST Brian McAllister
Prev: Re: AlarmHandler - filtering vs. HYST Brian McAllister
Next: Re: AlarmHandler - filtering vs. HYST Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
