Im trying to use the
same home (HVEL) and normal velocity (VELO) setting on a motion
controller. I am attempting to set HVEL. Documentation says that
VBAS<=HVEL<=VMAX. I can set VBAS ok in my database, but VMAX
will not set. Also, no matter what value I put into HVEL, I always end up
with a HVEL=VBAS.
All my issues are at
DB initialization. If i use Dbputs after initialization, the HVEL and VMAX
fields set properly.
Ive also noted that
if VBAS=VELO then the acceleration commands in device support are never
called. Therefore I cannot set VBAS=VELO=HVEL in my database for
initialization. I dont have a base velocity on this motion
controller.
My solution thus far
is to make VBAS, and HVEL slightly different from VELO.
Would appreciate any
advice.
Thanks very
much,
Dr. Mark Clift.
Beamlines Control Systems
Engineer
Australian Synchrotron
Project
Major Projects of Victoria
800 Blackburn Road
Clayton VIC 3168
Tel: +613 8540 4264
Fax: +613 8540 4200
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
