Kay,
Actually, it looks like there may be another interpretation. The product
name is defined as (DeviceNet?) type SHORT_STRING. I don't know where
this is defined but it looks like it may be: "a single byte length field
and 'n' data bytes".
In which case the Product Name is being returned inside a longer field.
The Product Name is less than 32 characters but the data field it is
returned in is longer than 32 bytes.
EIP_check_interface() rejects the product name because is finds the
length of the data returned >32, even though the string length is less
than 32.
John
Kay-Uwe Kasemir wrote:
On Apr 6, 2006, at 10:22 , John Dobbins wrote:
I just found in Volume I : CIP Common Specification, Release 1.0, page
5-10
"Product Name:
This text string should represent a short description of the
product/product family represented by the product code in attribute 3.
The same product code may have a variety of product name strings. The
maximum number of characters in this string is 32."
Excellent, so now you can sue the makers of ControlLogix for violating
the spec ;-)
How _did_ you get a copy of the updated specs?
-Kay
- Re: Ethernet/IP Device Support and CompactLogix Carl Cork
- Ethernet/IP Device Support and CompactLogix John Dobbins
- Re: Ethernet/IP Device Support and CompactLogix Kay-Uwe Kasemir
- Re: Ethernet/IP Device Support and CompactLogix John Dobbins
<2006>
<2006>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
