1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: EPICS record names: disallowed characters?
To: "Tim Mooney" <[email protected]>, "Rock, Judith E." <[email protected]>
Cc: <[email protected]>, "Miller, Edward S." <[email protected]>
Date: Thu, 6 Apr 2006 05:59:37 -0700
It is probably a good idea to avoid using [ and ] as version 4 will have array support and these will have a special meaning in the names. Also "." is the delineation between name and field - and with version 4 support for structures, this will be the delimitor between structure and strucutre elements.
Marty should comment is this is not correct.
Bob
Here's the relevant section from the Application Developer's Guide:
6.3.2 Unquoted Strings
In the summary section, some values are shown as quoted strings and some unquoted. The actual rule is that any string consisting of only the following characters does not have to be quoted:
a-z A-Z 0-9 _ - : . [ ] < > ;
These are also the legal characters for process variable names. Thus in many cases quotes are not needed.
Tim Mooney ([email protected]) (630)252-5417 Beamline Controls & Data Acquisition Group Advanced Photon Source, Argonne National Lab.
Prev: Re: EPICS record names: disallowed characters? Tim Mooney
Next: Re: Ethernet/IP Device Support and CompactLogix John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: pvPut() in entry()? Laznovsky, Michael
