1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EpicsHostArch.pl for Intel OS X machines?
To: Eric Norum <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 04 Apr 2006 22:15:43 -0400
On Tue, 2006-04-04 at 20:27 -0500, Eric Norum wrote:
> I'm trying to add Intel OS X support to EPICS.  The EpicsHostArch
> shell script changes are easy:
> Index: EpicsHostArch
> RCS
> file: /net/phoebus/epicsmgr/cvsroot/epics/base/startup/EpicsHostArch,v
> retrieving revision 1.6.4.2
> diff -u -r1.6.4.2 EpicsHostArch
> --- EpicsHostArch       1 Nov 2005 17:26:50 -0000       1.6.4.2
> +++ EpicsHostArch       5 Apr 2006 01:24:01 -0000
> @@ -39,6 +39,7 @@
>         cpu=`uname -m`
>          case "$cpu" in
>              "Power Macintosh") cpu=ppc ;;
> +            "i386") cpu=x86 ;;
>          esac
>         echo ${os}-${cpu}${suffix}
> I've hit a roadblock with EpicsHostArch.pl, though.  The script uses
> $Config{'archname'} to get the host information, but on both Power PC
> and Intel OS X machines this gives: darwin-thread-multi-2level
> Any perl experts out there that can suggest a way to determine the CPU
> architecture?
Don't you want to leave it as "thread-multi-2level"?
Apple uses a new ABI which means the same binary runs on PPC and INTEL,
hmmm?
I would use whatever GCC uses to make the "CROSS".
Ernest
> Advanced Photon Source
> Argonne National Laboratory
> (630) 252-4793
Re: EpicsHostArch.pl for Intel OS X machines? Eric Norum
Prev: EpicsHostArch.pl for Intel OS X machines? Eric Norum
Next: Re: EpicsHostArch.pl for Intel OS X machines? Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
