Hi Rodney,
you can do
nm<arch> *.o | grep _sysIntEnablePIC
on all object files which are included in your ANC library to find out
which code uses that function. In you case, nm<arch> is probably nm68k
and maybe you have to specify the complete path (same directory as your
cross-compiler).
Most sys* functions are defined in the vxWorks BSP for your board. If
they are missing, you have probably board-depending driver code which
has been compiled for the wrong board. Are macro definitions missing or
wrong?
Dirk
Porter, Rodney R. wrote:
I am running EPICS 3.14.8.2, vxWorks T2.2, synApps 5_1_1 with upgrades
to motor 5-8 and asyn 4-4 to get streamDevice to work.
For vxWorks-68040 I get the following load errors:
ld < ANC.munch
undefined symbol: _sysIntEnablePIC
undefined symbol: _sysVectorIRQ0
ld error: Module contains undefined symbol(s) and may be unusable.
value = 0 = 0x0
For vxWorks-ppc604_long I get the following load error:
ld < ANC.munch
undefined symbol: sysIntEnablePIC (binding 1 type 0)
value = 0 = 0x0
I am assuming that these mean that some vxWorks system calls are not
getting properly registered. Does anyone have a fix, or can anyone
direct me to where the fix needs to be implemented (vxWorks, base, asyn
Rodney Porter
Sr. Scientific Programmer
Data Aquisition & Detector Systems
Intense Pulsed Neutron Source
Argonne National Laboratory
9700 So. Cass Ave
Argonne, IL 60439 USA
Ph. (630) 252-7151
E-mail: [email protected] <mailto:[email protected]>
IPNS website: www.pns.anl.gov
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax +41 56 310 4413
- ld error: Module contains undefined symbol(s) and may be unusable. Porter, Rodney R.
Re: snc/seq enhancements ... local-variable access Eric Norum
<2006>
EpicsHostArch.pl for Intel OS X machines? Eric Norum
<2006>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
