Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: snc/seq enhancements ... local-variable access
From: "Laznovsky, Michael" <lazmo@slac.stanford.edu>
To: <tech-talk@aps.anl.gov>
Cc: "Laznovsky, Michael" <lazmo@slac.stanford.edu>
Date: Tue, 4 Apr 2006 00:00:38 -0700
Greetings EPICS fans- I'm sending this email to solicit suggestions and comments
for some snc/seq enhancements I'm working on, in this case support for access to
local variables within sequence code.
Access is provided by show/get/put functions, and also via special PVs when a
small database is added to the IOC.  Progress thus far includes snc producing
the required data structures and the aformentioned seq functions.  For example,
the following illustrates a set of declarations in a source file and the output
of a series of "seqVarShow" calls:
	char         errmsg[256];
	char        *pbuf;
	char        *pbuf2;
	short        n;
	int          xyz[5][10];
	unsigned int m;
	long         foo;
	float        a;
	double       z;
Get thread ID:
	epics> seqShow
	Program Name     Thread ID  Thread Name      SS Name
	zz99Control      1e7a80     zz99seq          zz99_ctrl
"seqVarShow" with no arguments displays all local variables in all state
programs (or you can provide the thread id as an argument to limit output):
	epics> seqVarShow
	Program: zz99Control
	  Name                  Type            [n][n]  Address Value
	  errmsg                char            [256]   1e5334  "0"
	  pbuf                  char *                  1e5434  (NULL)
	  pbuf2                 char *                  1e5438  192270 -> "90 0 34 ..."
	  n                     short                   1e5448  "-77"
	  xyz                   int             [5][10] 1e5536  "3"
	  m                     unsigned int            1e544c  "1"
	  foo                   long                    1e5330  "0"
	  a                     float                   1e543c  "1.0"
	  z                     double                  1e5328  "0.1873811581904769"
"seqVarGet" with thread ID and variable name displays just that variable:
	epics> seqVarGet 1e7a80,"z"
	"0.9685835438816328"
"seqVarPut" with thread ID, variable name, and value (as string) modifies
the variable:
	epics> seqVarPut 1e7a80,"m","33"
	epics> seqVarGet 1e7a80,"m"
	"33"
Things to note (all preliminary at this point):
Both reentrant and non-reentrant cases are properly handled.
Variables of type "pointer" are resolved, so that the objects pointed to are
get/put, rather than the pointers themselves (unless the pointer is NULL).
Maybe provide a way to alter the pointer itself?
Character arrays (strings) are displayed/entered as numeric byte sequences
(could be selectable?).
Need a general way to get at arbitrary array elements.  Currently only the
first element is accessible.
While local variables are file-scoped (and thus shared by all state sets within
a given source file) the only way I see to uniquely identify a collection of
them is via a "thread ID"... "program name", "thread name", and "SS name"
are all potentially subject to collisions when multiple sequences are loaded
and/or invoked.
Short-term future plans include database and EDM display infrastructure to support
run-time debugging of state programs, including state single-stepping and forced
out-of-order transitions.
Feedback welcomed.
Mike
Re: snc/seq enhancements ... local-variable access Tim Mooney
Re: snc/seq enhancements ... local-variable access J. Lewis Muir
Prev: EPICS Training Course, Cambridge, England. July 2006 Philip Taylor
Next: RE: snc/seq enhancements ... local-variable access Dalesio, Leo `Bob`
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Next: Re: snc/seq enhancements ... local-variable access Tim Mooney
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
