1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: seq 2.0.11 now available
To: <[email protected]>
Cc: "Laznovsky, Michael" <[email protected]>
Date: Mon, 3 Apr 2006 12:22:18 -0700
Greetings- snc/seq version 2.0.11 is now available on the SLAC ftp site:
	http://www.slac.stanford.edu/comp/unix/package/epics/sequencer/
According to Andrew Johnson, "the build has been tested against versions
of Base going back to R3.14.7".
Additions to the "NOTESbyMRK" file since seq 2.0.10:
> When you run a standalone sequencer the -s option provides iocsh.
> If the -s option is not given no shell is started.
> For example
>      ./sncProgram -s "user=mrkHost"
>      epics>
> The iocsh shell provides a help command to see what commands are available.
> Version 2.0.11 contains the following changes:
> A bugfix in src/seq/seq_ca.c found by Stephanie Allison and Till Straumann.
> Moved the PV build configuration variables from configure/RELEASE to the new
> CONFIG_SITE file, and moved CONFIG_APP functionality into CONFIG. Also set
> CHECK_RELEASE to YES by default in configure/Makefile.
Please advise of any problems.
Mike
Michael P. Laznovsky                         mailto:[email protected]
Application Software Developer, CPE                     ofc: (650) 926-2924
Stanford Linear Accelerator Center, MS-46               fax: (650) 926-3515
2575 Sand Hill Road, Menlo Park CA 94025 USA   http://www.slac.stanford.edu
Prev: RE: IOC shutdown signal(s) Al Honey
Next: RE: IOC shutdown signal(s) Thompson, David H.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: IOC shutdown signal(s) Thompson, David H.
Next: EPICS Training Course, Cambridge, England. July 2006 Philip Taylor
