Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: RE: Exiting IOC
To: <kimkh@nfrc.re.kr>, <tech-talk@aps.anl.gov>
Date: Sun, 2 Apr 2006 20:46:42 -0500
One way to do this, but probably not the most elegant, is to call your C cleanup function directly at the end of your main() routine for that IOC.
int main(int argc,char *argv[])
        if(argc>=2) {
        iocsh(argv[1]);
        epicsThreadSleep(.2);
    iocsh(NULL);
    /* Call your cleanup function here */
    return(0);
Sent: Sun 4/2/2006 7:58 PM
To: tech-talk@aps.anl.gov
Subject: Exiting IOC
Dear ALL;
When I type "exit" on IOC shell, I would like to call a particular function to return system resource and then want to terminate the IOC. Is there any mechanism to register the particular function?
Now, I register the particular function as IOC shell command and I call it on the shell before finish IOC. But, I forget it frequently, so, it is inconvenient.
Thank you.
Kukhee Kim
April 1, 2006
Kukhee Kim
National Fusion Research Center
52 Yeoeun-dong, Yusung-gu, Daejeon 305-333
Korea
Email: kimkh@nfrc.re.kr
Tel: +82 42 870 1616     Fax: +82 42 870 1609      Cell: +82 17 513 4849
Prev: Exiting IOC kimkh
Next: LabVIEW and ChannelAccess? Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Prev: Re: Exiting IOC Andrew Johnson
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
