1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: scaler record medm problems
Cc: [email protected]
Date: Fri, 31 Mar 2006 07:12:27 -0500
Mark Rivers wrote:
On the older Linux system the scaler CNT widget behaves badly, as
described previously.  This version is:
corvette> more /proc/version
Linux version 2.4.20-20.9smp ([email protected]) (gcc
version 3.2.2 20030222 (Red Hat Linux 3.2.2-5)) #1 SMP Mon Aug 18
11:32:15 EDT 2003
On a newer Linux system the scaler CNT widget behaves fine.  This
version is:
vincent> more /proc/version
Linux version 2.6.9-22.0.1.EL ([email protected]) (gcc version 3.4.3
20050227 (Red Hat 3.4.3-22.1)) #1 Thu Oct 27 10:38:16 CDT 2005
Since I am running exactly the same medm binary on exactly the same X
server, the only difference is the run-time libraries that are present
on the Linux system that is running medm.  There must be a problem with
the X libraries on the old Redhat 2.4.20 system.
They probably fixed it in 2.4.21 of my Linux system, where the scaler CNT
widget behaves fine.  This version is
feng> more /proc/version
Linux version 2.4.21-15.0.3.EL ([email protected]) (gcc version 3.2.3 20030502 (Red Hat Linux 3.2.3-37)) #1 Tue Jun 29 18:17:52 EDT 2004
I conclude that there
is no problem with the scaler record or with medm.
Agree!
Kate
-----Original Message-----
Sent: Thursday, March 30, 2006 4:55 PM
To: 'Tim Mooney'
Cc: 'Kenneth Evans, Jr.'; 'Jeff Hill'; 'Dirk Zimoch';
'Leicester, PJ (Pete)'; 'Ralph Lange (BESSY)'; 'Ned Arnold';
'Andrew Johnson'
Subject: scaler record medm problems
Folks,
I have applied this fix to the scaler record.  I used
camonitor on the CNT field, and indeed it fixes the problem
of two monitors being posted for CNT=Count when acquisition starts.
However it does NOT fix the problem with medm on Linux.  medm
running on Windows continues to work fine, medm running on
Linux (but displaying on Windows or Linux) does not work. The
Count/Done choice button gets into a weird state with both
states selected, not sending events, etc.
So the question is why is that particular choice button messing up?
- It does not have to do with 2 monitors being posted quickly
on the PV it controls.
- It should not have to do with the caPutCallback behavior of
the scaler record, because medm does not use caPutCallback, right?
Any ideas what to look for next?
Sent: Thursday, March 30, 2006 2:14 PM
To: Mark Rivers
Cc: Tim Mooney; Kenneth Evans, Jr.; Jeff Hill; Dirk Zimoch;
Leicester, PJ (Pete); Ralph Lange (BESSY); Ned Arnold;
Andrew Johnson
Subject: Re: gateway enum writes
Tim Mooney wrote:
 > There's an error in the scaler software.  It should not be
posting CNT
 > unless it changed CNT.  This will take some time to fix
thoroughly, but
 > at least the record should never post CNT = 0 ("Done"),
because it never
 > sets CNT to this value.  I've committed this fix to cvs.
 The other
 > transition will take some thought, because 1->0 can come
from the user
 > and from device support, and these can race.
Oops.  This hasn't been true for a long time.  I *can* post
at the time of
change, and I actually committed that bug fix.  Here are
the changes:
static long process(pscal)
	/* If we're being called as a result of a done-counting
interrupt, */
	/* (*pdset->done)(card) will return TRUE */
	if ((*pdset->done)(card)) {
		pscal->ss = SCALER_STATE_IDLE;
		/* Auto-count cycle is not allowed to reset
.CNT field. */
		if (pscal->us == USER_STATE_COUNTING) {
			pscal->cnt = 0;
+			db_post_events(pscal,&(pscal->cnt),DBE_VALUE);
			pscal->us = USER_STATE_IDLE;
			justFinishedUserCount = 1;
			if (pscal->ppn) putNotifyOperation = 1;
		if (handled) {
			pscal->pcnt = pscal->cnt;
-			Debug(2) "process: posting .CNT field
(%d)\n", pscal->cnt);}
-			db_post_events(pscal,&(pscal->cnt),DBE_VALUE);
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab
scaler record medm problems Mark Rivers
Prev: scaler record medm problems Mark Rivers
Next: Exiting IOC kimkh
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
