1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: gateway enum writes
To: "Kenneth Evans, Jr." <[email protected]>
Cc: [email protected]
Date: Thu, 30 Mar 2006 10:12:39 -0500
Just a comment about the Joerger scaler/MEDM
problem, which I do not think is related to gateway.
Kenneth Evans, Jr. wrote:
     On looking at the original message I can guess that you are using a
Joerger scaler.  The Joerger scaler does not play well with channel access.
It does not work well with MEDM, either on Solaris or Linux.  I investigated
this some time ago, to the extent I was convinced it was not MEDM.  The beam
line people that were using it at that time did not have enough expertise to
determine the real cause of the problem.  The same problem has appeared at
various sites since.
     My recollection is that the workaround for the Joerger scaler is to
push the buttons alternately to get it to be done.  You can also have two
screens and use the buttons on both of them.  You'll have to experiment.
I observed the above Joerger scaler/MEDM problem on my
RedHat7.3 Linux PC, but not on the RedHat9.0 Linux PC,
and other Debian Linux PCs in the beamlines.  In all
cases, the IOCs are run under EPICS3.14.x/RTEMS.
Kate
RE: gateway enum writes Kenneth Evans, Jr.
Prev: Re: gateway enum writes D. Peter Siddons
Next: RE: gateway enum writes Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
