I am getting some
strange behaviour when writing enumerations through the Gateway (version 2.0.0.0
on 3.14.8.2 and RedHat Enterprise 4).
The problem first
showed itself in edm when pressing a button on a edm screen to send the value
resulted in the following error:
CA.Client.Exception...............................................
Warning: "Virtual circuit unresponsive" Context: "diamrs0005l.diamond.ac.uk:6064" Source File: ../tcpiiu.cpp line 896 Current Time: Tue Mar 28 2006 16:19:01.334736000 .................................................................. I did some further
tests using caput with similar results:
[pjl45@pc0005 pjl45]$ caput -w15 GDA:scaler2.CNT
Count
Old : GDA:scaler2.CNT Done Read operation timed out: PV data was not read. New : GDA:scaler2.CNT CA.Client.Exception............................................... Warning: "Virtual circuit disconnect" Context: "op=0, channel=GDA:scaler2.CNT, type=DBR_TIME_STRING, count=1, ctx="diamrs0005l.diamond.ac.uk:6064"" Source File: ../getCopy.cpp line 82 Current Time: Tue Mar 28 2006 17:04:24.488496000 . Despite the above
error message the write does actually reach the IOC.
However if I
now try the change the value back as follows:
caput -w15 GDA:scaler2.CNT Done
Old : GDA:scaler2.CNT Count Read operation timed out: PV data was not read. New : GDA:scaler2.CNT CA.Client.Exception............................................... Warning: "Virtual circuit disconnect" Context: "op=0, channel=GDA:scaler2.CNT, type=DBR_TIME_STRING, count=1, ctx="diamrs0005l.diamond.ac.uk:6064"" Source File: ../getCopy.cpp line 82 Current Time: Tue Mar 28 2006 17:22:36.167980000 .................................................................. I get an error again
however this time the 'Done' value gets written to the IOC
exactly ONE MINUTE after I entered the caput command. This is long
after the caput command has timed out so it appears the gateway is responsible
for the delay?
Has anyone any idea
what may be happening? Is there a 60 second timeout in CA or the gateway which
may give a clue as to what I am seeing?
(For the record this
test was done with a very lightly loaded test gateway serving only 20 or
so PV's. Also using caput -w70 results in the same
timeouts)
Pete Leicester
Senior Software Engineer
Diamond Light Source Ltd.
Rutherford Appleton
Laboratory
Chilton
Didcot
OX11 0QX
Tel: 01235 778478
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
