Hi Al,
relax.
These conflicts occur when the grammar that antelope builds the parser
for has ambiguities. At the point where antelope realizes there might
be a situation where the parser has two choices in interpreting the
input, it issues a warning and makes the parser deliberately select one
of the choices.
The IBM Aix documentation has a nice one
page explanation for what's happening.
Of course one could try to change the grammar to remove the
ambiguities, but the conflicts occur most often in places where you
really don't care and both choices would be working anyway, so ...
Hope this helps,
Ralph
Al Honey wrote:
Aloha
This is more ignorance on
my part. Do I need to track down
the cause of the warnings in the input file or do I ignore these as
there is a
function call to remove_conflicts() (i.e. does that function fix things
or
delete the stuff that was found to be errant from the output?)? If the
input
file needs to be fixed is there a mechanism for enabling more error
message so
as to find the lines in question?
/usr/local/epics/r3.13.10/base/bin/solaris/antelope
-t ../pvload.y
/usr/local/epics/r3.13.10/base/bin/solaris/antelope:
4 shift/reduce conflicts, 5
reduce/reduce
conflicts.
mv y.tab.c
pvload.c
Thanks for any help
AH
- antelope errors Al Honey
RE: Was this EPICS? Kevin Tsubota
RE: antelope errors Al Honey
<2006>
<2006>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
