1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: building 3.14.8.2 on win32-x86
To: "'Dale L. Brewe'" <[email protected]>, <[email protected]>
Date: Mon, 20 Mar 2006 08:53:13 -0700
> I'm curious whether anyone else has tried to build w/ Visual C 6 and
> encountered this problem, or if there is something unique about my
> environment???
MS is currently at version 8 and interest in version 6 is diminishing
at this point. The issue you have identified below illustrates the
lack of compliance with standards with version 6. Nevertheless, I
committed a patch to cvs.
Jeff
I found one thing that Visual C 6 does not like in dbMapper.cc:
for ( int i=0; i < db->no_str; i++ ) {
         enumStringTable.getString ( i,
             &(db->strs[i][0]), MAX_ENUM_STRING_SIZE );
         for ( int i = db->no_str; i < MAX_ENUM_STATES; i++ ) {
                 db->strs[i][0] = '\0';
It complains that the two "int i" statements are a multiple
declaration I believe. Changing the second i to a j removes the error.
environment???
dale brewe
  Dale L. Brewe
  PNC-CAT/Argonne National Laboratory
  ph: 630 252 0582         fax: 630 252 0580
  Mail:
  Bldg 435E sector 20
  9700 S. Cass Ave.
  Argonne, IL 60439 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
building 3.14.8.2 on win32-x86 Dale L. Brewe
Prev: RE: Pure virtual mode called Lawrence T. Hoff
Next: Re: problem building 3.14.8.2 with win32-x86 Janet Anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: building 3.14.8.2 on win32-x86 Dale L. Brewe
Next: Pure virtual mode called kimkh
