1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: -Wtraditional ?
To: Dirk Zimoch <[email protected]>
Cc: TECHTALK <[email protected]>
Date: Fri, 17 Mar 2006 16:54:21 -0600
The "-Wtraditional" option does not exist in R3.14 base/configure files
but it still exists in the base/config directory and appears on GNU
compiler compile lines for builds of extensions with R3.13 Makefiles.
I will remove the "-Wtraditional" option in the base/config directory
before the next R3.14 base release. Thanks.
Janet
Dirk Zimoch wrote:
I noticed that building some extensions (casr, StripTool) with R3.14.8.2 gives really many warings about things that would not work in traditional C.
Why is -Wtraditional now switched on for non -traditional builds?
I am using gcc on linux-x86 architecture.
Dirk
-Wtraditional ? Dirk Zimoch
Prev: problem building 3.14.8.2 with win32-x86 Dale L. Brewe
Next: Fwd: problem building 3.14.8.2 with win32-x86 Dale L. Brewe
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: -Wtraditional ? Dirk Zimoch
Next: problem building 3.14.8.2 with win32-x86 Dale L. Brewe
