1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: archiveViewer JSP build
To: "Vladimir Sirotenko" <[email protected]>, [email protected]
Cc: [email protected]
Date: Thu, 16 Mar 2006 08:24:00 -0600
Yury and I checked the production machine (and the test machine), but
we don't see jaxp-parser-impl installed.
I would recommend installing for it first, before you do nodep option.
 With Scientific Linux, you should be able to use yum or apt-get to
downlowd what you need easily.
If I remember correctly, on the production machine, when we tried to
install something, either ant or jpackage-utils, it complained,
despite the fact that we had the needed package installed with the
correct version, so we used nodep option, as we decided it probably
won't break anything (and it didn't, as far as I can tell).
But in your case, unless you already have jaxp-parser-impl with the
right version installed on your computer to begin with, you probably
try installing/updating that package first.
On 3/15/06, Vladimir Sirotenko <[email protected]> wrote:
> Thanks. Following you recommendation, I uninstalled native ant, installed
> jpackage-utils from rpm and when try to install ant, got the following that
> package jaxp-parser-impl is needed .. Did you see that also? Probably, I
> also should install it with -nodep option ..
> Thanks,
> Vladimir
> From: "Jiro Fujita" <[email protected]>
> To: <[email protected]>
> Cc: "Vladimir Sirotenko" <[email protected]>
> Sent: Wednesday, March 15, 2006 12:34 PM
> Vladimir,
> We (Creighton University STAR/RHIC slow control team) have encountered
> the same problem a month or so ago.  We were trying to install Archive
> Viewer on Scientific Linux 3.0.5.  After spending hours trying to fix
> the  similar errrors (including the same one for that matter), Here is
> what we discovered.  In the essence, we uninstalled Apache ANT that
> came installed with SL3, and installed separately build version I
> found on the web.
> Here is what I posted on the Tech-talk once I found the solution:
> http://www.aps.anl.gov/epics/tech-talk/2006/msg00219.php
> I also included where I got all the necessary RPMs in that posting as well.
> It looks that there is something funny about the Apache ANT package
> supplied by RedHat Enterprise Linux 3 (therefore, Scientific Linux 3
> as well as Fermi version).  I saw a few people complaining about that
> and suggesting to use a version different from RHEL version.  It
> worked for us for that.
> I was under impression that Sergei Chevtsov was going to update the
> instruction based upon what we saw, but may be he hasn't gotten to it,
> yet.
> We may put information on this on our webpage at some point as well,
> in case somebody else is interested in for the future reference.
> On our test setup computer, I was able to install Apache ANT just fine
> with standard rpm -U command, however, for our production machine, we
> had some issues with that, and ended up installing Apache ANT with
> -nodep option.  It could be dangerous and I really didn't wanted to do
> that, but sometimes, you have no other choices, and in this case, it
> worked just fine.
> Finally, here is what we are using, in case you are interested:
> Apache Ant: ant-1.6.2-3jpp.noarch.rpm
> Java:             j2sdk1.4.2_09 (I think...  We also used jdk1.5.0_06
> as well...)
> Apache Tomcat: apache-tomcat-5.5.15
> Well, good luck.
> On 3/14/06, Vladimir Sirotenko <[email protected]> wrote:
> > Hi,
> > I am building archiveViewer JSP on Scientific Linux Fermi LTS 3.0
> > and it failed with the following errors:
> > d0olk->ant configure_jsp
> > Buildfile: build.xml
> > -create_build_dir:
> > build_all:
> >     [javac] Compiling 842 source files to
> > /online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/build
> >     [javac]
> > /online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/org/jfree/chart/encoders/SunPNGEncoderAdapter.java:41:
> > error: Class or interface `javax.imageio.ImageIO' not found in import.
> >     [javac]    import javax.imageio.ImageIO;
> >     [javac]           ^
> >     [javac]
> > /online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/org/jfree/chart/encoders/SunJPEGEncoderAdapter.java:44:
> > error: Class or interface `com.sun.image.codec.jpeg.JPEGEncodeParam' not
> > found in import.
> >     [javac]    import com.sun.image.codec.jpeg.JPEGEncodeParam;
> >     [javac]           ^
> >     [javac]
> > /online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/org/jfree/chart/encoders/SunJPEGEncoderAdapter.java:124:
> > error: Type `JPEGImageEncoder' not found in the declaration of the local
> > variable `encoder'.
> >     [javac]            JPEGImageEncoder encoder =
> > JPEGCodec.createJPEGEncoder(outputStream);
> >     [javac]            ^
> >     [javac]
> > /online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/org/jfree/chart/encoders/SunJPEGEncoderAdapter.java:125:
> > error: Type `JPEGEncodeParam' not found in the declaration of the local
> > variable `param'.
> >     [javac]            JPEGEncodeParam param =
> > encoder.getDefaultJPEGEncodeParam(bufferedImage);
> >     [javac]            ^
> >     [javac]
> > /online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/epics/archiveviewer/xal/view/tooltip/MultiLineToolTipUI.java:17:
> > error: Class or interface `javax.swing.plaf.basic.BasicToolTipUI' not
> > found in import.
> >     [javac]    import javax.swing.plaf.basic.BasicToolTipUI;
> >     [javac]           ^
> >     [javac]
> > /online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/epics/archiveviewer/xal/view/tooltip/MultiLineToolTipUI.java:25:
> > error: Superclass `BasicToolTipUI' of class
> > `epics.archiveviewer.xal.view.tooltip.MultiLineToolTipUI' not found.
> >     [javac]    public class MultiLineToolTipUI extends BasicToolTipUI
> >     [javac]                                            ^
> >     [javac]
> > /online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/epics/archiveviewer/xal/view/tooltip/MultiLineToolTipUI.java:0:
> > internal compiler error: Segmentation fault
> >     [javac] Please submit a full bug report,
> >     [javac] with preprocessed source if appropriate.
> >     [javac] See <URL:http://bugzilla.redhat.com/bugzilla/> for
> > instructions.
> > BUILD FAILED
> > file:/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/build.xml:21:
> > Compile failed; see the compiler error output for details.
> > My settings are:
> > d0olk->echo $JAVA_HOME
> > /usr/java/j2sdk1.4.2_08
> > d0olk->echo $CATALINA_HOME/
> > /mnt/tomcat/jakarta-tomcat-3.2.4/
> > Can someone give any suggestions?
> > Thanks,
> > Vladimir
archiveViewer JSP build Vladimir Sirotenko
Re: archiveViewer JSP build Jiro Fujita
Prev: Re: archiveViewer JSP build Jiro Fujita
Next: -Wtraditional ? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: bc635 driver bug (Bancomm) Al Honey
