OK, so if I understand this, you're saying the bootROM client downloads the boot image and disconnects before the data connection is closed, before the server is listening for the command, and the server sits there waiting until it times out. But, if the bootROM client has successfully downloaded the file, shouldn't I see it boot, and then hang when it tries to download the script file because the server is still waiting on the original connection? What I see is basically nothing happening for a long time, then after the seven minutes are up, I see the vxWorks logo and such, then the script file is downloaded very quickly. I think you got the order mixed up slightly there: the vxWorks client gets all of the data, but then as part of its tidy up procedure it sends a QUIT command to the server *before* closing the data socket. The server however is insistant on fully closing the data socket before it will listen to the next command though, so it waits until that close process times out (a TCP socket timeout of some kind) before it will accept the QUIT and actually close the command socket. This matches your symptoms because the file transfer is not regarded as completely over until the connection has been closed, so the bootrom won't continue on to print the logo until then. Also, I've noticed a problem w/ WS_FTP trying to download the same vxWorks.st from the same server - in that case I get a graphical indicator and it looks like the file transfer itself is very abnormally slow. I don't know what's happening there, but it's a different client anyway. - Andrew -- There is no S in exprexxo.
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
