1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem with e_flex in base
Cc: [email protected]
Date: Tue, 28 Feb 2006 11:24:39 -0600
Hi Mark,
Mark Rivers wrote:
I have found a problem with e_flex in base (3.14.8.2). It does not handle .l files that have DOS terminators, which is what happens if one un-tars EPICS base on a Cygwin system and tries to build it.
What program did you use to extract everything out of the tar file?
If you're going to build EPICS using Cygwin, you should use the Cygwin version of tar to do that extraction, which will only convert the Unix line endings into DOS ones if your Cygwin installation is configured to use DOS line endings. In that configuration, the Cygwin C runtime library automatically does the right thing with line endings and e_flex should work properly without any changes.
Would it be possible to fix e_flex so this does not happen?
I have developed a fix, but I'm reluctant to commit it since I believe the problem was really due to operator error.
Is this reasonable?
- Andrew
There is no S in exprexxo.
Problem with e_flex in base Mark Rivers
Prev: medm edm and newer GUI Emmanuel Mayssat
Next: RE: Problem with e_flex in base Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Problem with e_flex in base Mark Rivers
