1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: EZCA win32
To: <[email protected]>
Cc: <[email protected]>
Date: Fri, 24 Feb 2006 17:48:37 +0100
I just tried your suggestion and that works much better.
I did not test all configurations, but my code is now stable.
Thank a lot, that was very simple!
-----Message d'origine-----
De : Benjamin Franksen [mailto:[email protected]]
Envoyé : vendredi 24 février 2006 17:21
À : [email protected]
Objet : Re: EZCA win32
On Friday 24 February 2006 17:02, URIOT Didier     DAPNIA wrote:
> Thank, for you answer.
> In fact, I'm using the Easy CA library (compiled with BuilderC++ 6.0)
>  linked with ca.dll, cas.dll, com.dll, msvcr71.dll, msvcp71,
> cygwin1.dll.
> All these DLL have been made with the 3.14.8 epics base compiled with
> VisualC++ Net.
> So, perhaps, something is not compatible. I don't know. (But,
> compilation and linking look like good).
> Or the DLL have some problems. At present, the person which made
> them, have a look to check it.
I would rather use the CA client library calls directly (you need only
ca.dll and com.dll). See the epics example application for a CA client
'hello world (use 'makeBaseApp.pl -t caClient caex' and then look at
caexApp/caExample.c).
Ben
Prev: Re: EZCA win32 Benjamin Franksen
Next: edm and Linux window manager Rolf Keitel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Looking for Application Example John Dobbins
