1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: error while compiling channelArchiver2.x
To: tech talk <[email protected]>
Date: Wed, 22 Feb 2006 11:17:34 -0500
Hello:
I have no good answer for this,
other than you might have to try to
figure out which CtrlInfo.h is actually getting included
when you compile LibIO/CtrlInfo.cpp,
since the errors indicate that the info
that should result from the #include "CtrlInfo.h"
a few lines above the errors that you get
should have taken care of the problem.
-Kay
On Feb 21, 2006, at 23:17 , liushu wrote:
Hello:
I have ever installed channelArchiver2.x with the default
installation(/usr/local) successfully.Now I want to install it again in my
own directory(/home/liushu/epicsinstall/base3.14.7/extensions/),I Have
installed all the third party successfully,but when I compile
channelarhiver,I got errors like:
gmake[2]: Entering directory
`/home/liushu/epicsinstall/base3.14.7/extensions/src/ ChannelArchiver/LibIO/O.linux-x86'
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux
-D_REENTRANT -ansi -g -Wall
-D ARCH_VERSION=2 -D ARCH_RELEASE=6 -D ARCH_PATCH=0 -D
ARCH_VERSION_TXT=\"2.6.0\"
-I/home/liushu/epicsinstall/base3.14.7/base/include
-I/home/liushu/epicsinstall/base3.14.7/base/include/os/Linux
-I../../../../xerces-c-src2_4_0/include
-g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../ include
-I/home/liushu/epicsinstall/base3.14.7/base/include ../ CtrlInfo.cpp
../CtrlInfo.cpp:8: parse error before `::' token
../CtrlInfo.cpp:12: syntax error before `.' token
error while compiling channelArchiver2.x liushu
Prev: error while compiling channelArchiver2.x liushu
Next: Problem with e_flex in base Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
