1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: genSub tutorial needed
To: [email protected]
Cc: [email protected], [email protected]
Date: Tue, 21 Feb 2006 09:23:41 -1000
>>>>> "Tim" == Tim Mooney <[email protected]> writes:
 Tim> Dennis Nicklaus wrote:
 >> Here's what I want to do: 1. Have a function which would create two
 >> arrays, I and Q,  of N points each, using several input parameters
 >> (values of other PVs) whenever any of the other PVs is set.
 >> 2. Copy these 2 arrays out to two separate VME memory address locations
 >> (I'm copying an array to an array of addresses, not
 >> each-element-in-the-array-to-the-same-address as in a FIFO).
 Tim> The genSub record does not talk to device support.  If you want to
 Tim> write to hardware, you have to get some other record to do it.
 Tim> ....
 Tim> 2. Write device support for the waveform record to write the arrays
 Tim> to hardware.  Probably you'll want to use a setup routine, callable
 Tim> from st.cmd, to give the waveform records their target address.
If I read the question correctly, I'd "just" have the genSub code write to
the VME memory directly.  There doesn't need to be device support for that.
Jim
Re: genSub tutorial needed Peregrine McGehee
genSub tutorial needed Dennis Nicklaus
Re: genSub tutorial needed Tim Mooney
Prev: Re: genSub tutorial needed Tim Mooney
Next: Re: genSub tutorial needed Peregrine McGehee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
