Hello Margaret,
This is mantis entry 239.
The issue you have discovered occurs only when calling ca_context_create
(a.k.a. ca_task_initialize) from your C++ file scope object's constructor.
The static variable "ca_client_context::defaultServiceInstallMutex" is also
file scope, and this implies that it's constructor along with the
constructor of your device_attr_stubs both run before main() is called.
Which file scope constructor runs first is very C++ compiler implementation
dependent.
Let me know if the attached patch resolves your troubles.
Jeff
cvs diff -u -wb -i -- ca_client_context.cpp oldAccess.h (in directory
D:\users\hill\R3.14.dll_hell_fix\epics\base\src\ca\)
Index: ca_client_context.cpp
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/base/src/ca/ca_client_context.cpp,v
retrieving revision 1.9.2.18
diff -c -u -w -b -i -r1.9.2.18 ca_client_context.cpp
cvs diff: conflicting specifications of output style
--- ca_client_context.cpp 13 Apr 2005 17:28:13 -0000 1.9.2.18
+++ ca_client_context.cpp 17 Feb 2006 22:22:11 -0000
@@ -47,6 +47,7 @@
epicsThreadPrivateDelete ( caClientCallbackThreadId );
caClientCallbackThreadId = 0;
+ delete ca_client_context::pDefaultServiceInstallMutex;
// runs once only for each process
@@ -54,13 +55,14 @@
caClientCallbackThreadId = epicsThreadPrivateCreate ();
assert ( caClientCallbackThreadId );
+ ca_client_context::pDefaultServiceInstallMutex = new epicsMutex;
epicsAtExit ( cacExitHandler,0 );
extern epicsThreadPrivateId caClientContextId;
cacService * ca_client_context::pDefaultService = 0;
-epicsMutex ca_client_context::defaultServiceInstallMutex;
+epicsMutex * ca_client_context::pDefaultServiceInstallMutex;
ca_client_context::ca_client_context ( bool enablePreemptiveCallback ) :
ca_exception_func ( 0 ), ca_exception_arg ( 0 ),
@@ -77,9 +79,7 @@
epicsThreadOnce ( & cacOnce, cacOnceFunc, 0 );
- // this wont consistently work if called from file scope
constructor
- epicsGuard < epicsMutex > guard (
ca_client_context::defaultServiceInstallMutex );
+ epicsGuard < epicsMutex > guard (
*ca_client_context::pDefaultServiceInstallMutex );
if ( ca_client_context::pDefaultService ) {
this->pServiceContext.reset (
& ca_client_context::pDefaultService->contextCreate (
@@ -88,7 +88,6 @@
else {
this->pServiceContext.reset ( new cac ( this->mutex,
this->cbMutex, *this ) );
this->sock = epicsSocketCreate ( AF_INET, SOCK_DGRAM, IPPROTO_UDP );
if ( this->sock == INVALID_SOCKET ) {
@@ -734,8 +733,9 @@
void ca_client_context::installDefaultService ( cacService & service )
- // this wont consistently work if called from file scope constructor
+ epicsThreadOnce ( & cacOnce, cacOnceFunc, 0 );
throw std::logic_error
( "CA in-memory service already installed and can't be
replaced");
Index: oldAccess.h
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/ca/oldAccess.h,v
retrieving revision 1.47.2.14
diff -c -u -w -b -i -r1.47.2.14 oldAccess.h
--- oldAccess.h 19 Oct 2004 20:48:51 -0000 1.47.2.14
+++ oldAccess.h 17 Feb 2006 22:07:21 -0000
@@ -286,6 +286,9 @@
void operator delete ( void * );
+extern "C" void cacOnceFunc ( void * );
+extern "C" void cacExitHandler ( void *);
struct ca_client_context : public cacContextNotify
public:
@@ -412,8 +415,10 @@
ca_client_context ( const ca_client_context & );
ca_client_context & operator = ( const ca_client_context & );
+ friend void cacOnceFunc ( void * );
+ friend void cacExitHandler ( void *);
static cacService * pDefaultService;
- static epicsMutex defaultServiceInstallMutex;
+ static epicsMutex * pDefaultServiceInstallMutex;
int fetchClientContext ( ca_client_context * * ppcac );
***** CVS exited normally with code 1 *****
- segmentation fault in ca_task_initialize running in Linux Margaret Votava
CA Port numbers now official Kay-Uwe Kasemir
genSub tutorial needed Dennis Nicklaus
<2006>
RE: segmentation fault in ca_task_initialize running in Linux Jeff Hill
<2006>
