We are looking for a low cost high performance PPC-based IOC to replace
the MVME2100 in the future. At some point we need to be ready for the
EOL of the MVME2100.
I have discovered the MVME3100 and currently have it running under
vxWorks 6.2 and EPICS R3.14.8.2.
ics-ioc-condor1>coreRelease
### EPICS IOC CORE built on Feb 17 2006
### EPICS R3.14.8.2-SNS1 $R3-14-8-2$ $2006/01/06 15:55:13$
value = 0 = 0x0
ics-ioc-condor1>
ics-ioc-condor1>version
VxWorks (for Motorola MVME3100-1152 - MPC8540) version 6.2.
Kernel: WIND version 2.8.
Made on Feb 17 2006, 08:28:38.
The MVME3100 is based on the E500 core. Are there any other users
moving to vxWorks 6.2?
I know WindRiver is expensive; so who will do an mv3100 RTEMS port? :)
I have run a set of performance tests from Marty's test suite
(performApp):
Processing 213,000 records/sec. That is twice the processing compared
to the MVME2100.
Of course, we will be running a lot more tests here and tweaking the BSP
as needed. For example, we have some applications that could use the
Signal Processing Engine (i.e. SPE support)
PS: WindRiver also offers a BSP for vxWorks 5.5.1
The following is an excerpt from the BSP documentation:
It consists of the
MPC8540 PowerQUICC III integrated processor with serial ATA, USB 2.0,
2eSST VMEbus interfaces, dual 64-bit/100MHz PMC sites, one flash bank
(with two boot blocks), dual 10/100/1000 Ethernet, one 10/100 Ethernet,
five serial ports, and a single SODIMM module.
The MVME3100 has its own transition board, but does not require one.
I have the following:
MVME3100-1152 667 MHz MPC8540 processor, 256MB DDR SDRAM, 64MB flash,
Gigabit Ethernet, SATA
And the most beautiful things is the list price of $1450 :)
Ernest L. Williams Jr.
SNS Control Systems Group
ORNL
segmentation fault in ca_task_initialize running in Linux Margaret Votava
CA Port numbers now official Kay-Uwe Kasemir
<2006>
Re: segmentation fault in ca_task_initialize running in Linux Margaret Votava
<2006>
