1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ArchiveDataServer errors
To: [email protected]
Cc: [email protected]
Date: Mon, 13 Feb 2006 09:30:29 -0500
On Feb 11, 2006, at 02:43 , liushu wrote:
According to the manual.pdf.I create directory
/var/www/html/archive/cgi,and copied
ChannalArchiver/XMLRPCServer/O.linux-x86/ArchiveDataServer
/var/www/cgi-bin/xmlrpc/ArchiveDataServer.cgi,and ChannalArchiver's example
serverconfig.xml,serverconfig.dtd to /var/www/cgi-bin/xmlrpc/,and add
following to httpd.conf:
<Directory "/var/www/html/archive">
Order Allow,Deny
Allow from from All
</Directory>
<Directory "/var/www/html/archive/cgi">
So you configure
/archive/cgi
to host the ArchiveDataServer CGI tool,
but then you try to execute it in
/cgi-bin/xmlrpc ??
Then I restart httpd by /etc/rc.d/init.d/httpd restart.I run
ArchiveDataClient.pl -u
http://192.168.20.155/cgi-bin/xmlrpc/ArchiveDataServer.cgi -i
I got these output:
not well-formed (invalid token) at line 1, column 0, byte 0 at
/usr/lib/perl5/vendor_perl/5.8.0/i386-linux-thread-multi/XML/ Parser.pm line
185
Well, it means that the client got to the web server,
and it received some response, but nothing that looked
like a valid XML-RPC response.
In this case it often helps to look at the raw data server response yourself:
  telnet my_web_server_host 80
  GET /cgi-bin/xmlrpc/ArchiveDataServer.cgi HTTP/1.0<RETURN>
  <RETURN>
You should see an error message about ``XML-RPC Fault: Expected HTTP method POST'',
indicating that the data server was launched correctly and
was looking for a proper XML-RPC request.
If you see only pages of binary-looking garbage, your web server
doesn't recognize ArchiveDataServer.cgi as a CGI program,
and instead of running it, you get a copy of it.
It might help to review which web directories you intend
to configure as CGI directories.
Refer to the manual for your web server how to do that.
The archiver manual can only give suggestions.
And I have some questions:As I know that ArchiveEngine is web server too,so
I want to know if I start ArchiveEngine I don't need to start httpd,right?And
if I start httpd I don't need to start ArchiveEngine either,right?
Correct, they're separate:
The engine takes samples and serves status info via its httpd,
your Apache or other httpd serves web pages and maybe data via the ArchiveDataServer.cgi
Or if I use
ArchiveDataServer,which one I need,ArchiveEngine or httpd running?
httpd like Apache which executes ArchiveDataServer as a CGI tool.
-Kay
ArchiveDataServer errors liushu
Prev: Re: ChannelArchiver build error D. Peter Siddons
Next: Re: some error about archive-viewer-14 Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: ArchiveDataServer errors liushu
Next: labCA crashes with bad PV Dennis Nicklaus
