At LANSCE, we have run two VSD 2992 serial highway drivers from the same crate without undo grief. We were only using a single processor, however (an MVME 167) and the two highways (which were both pretty heavily loaded) were a bit of a strain on the CPU, so we eventually moved the second highway to its own crate. The EPICS Camac driver still uses "module_types.h", which is a bit anachronistic, but does have the advantage that all you have to do is set the two modules to different addresses (within the range specified by "module_types.h") and the software will automatically recognize both branches. Hope this is helpful. -Eric Bj. On Feb 6, 2006, at 9:38 AM, Evgeniy Tikhomolov wrote: We split our EPICS/CAMAC system into two loops. <><><><><><><><><><><><><><><><><><><><><><><><><><><><> Eric Björklund Los Alamos Neutron Science Center (LANSCE) phone: 505-667-6031 email: [email protected] <><><><><><><><><><><><><><><><><><><><><><><><><><><><> TSPA :: DUSA=ADTO
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
