1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Channel Archiver on Scientific Linux
To: [email protected]
Date: Fri, 10 Feb 2006 12:26:01 +0100
Hi all,
I just installed channel archiver (dated 2005-11-07) on Scientific Linux 4.1
(http://www.scientificlinux.org), which is a derivate of RedHat Enterprise.
gcc's version is 3.4.3.
I followed the installation instructions in the manual and below are some comments/additions to what is already written. I hope somebody will find
these remarks useful.
 Gasper Pajor
o) w3c-libwww-devel
The w3c-libwww sources supplied with archiver did compile but xmlrpc's configure
didn't find it (probably path/location issues). I just grabbed the package from
internet and it worked ok;
su -c "yum install w3c-libwww-devel"
o) xml rpc
I applied both patches mentioned in the manual and changed line 104 in
extensions/src/ChannelArchiver/ThirdParty/xmlrpc-c-0.9.9/src/validatee.c where
default:
was changed to
default:;
in order to prevent compiler error.
o) xerces
Added
#include <xercesc/framework/MemoryManager.hpp>
to
extensions/src/ChannelArchiver/ThirdParty/xercesc/util/RefArrayOf.hpp
as mentioned in manual.
o) XML-Simple and Frontier
Worked exactly as described in manual.
o) some general notes
- /usr/local/bin is not by default included in path which causes archiver making
(when calling xmlrpc-c-config) to fail. Just
export PATH=$PATH:/usr/local/bin
- I omited 'o' switch when extracting third party archives to prevent "Cannot
change ownership" errors.
- Remember to run "make" in extensions/configure prior to making
ChannelArchiver.
Re: Channel Archiver on Scientific Linux Ralph Lange
Prev: some error about archive-viewer-14 liushu
Next: Re: Channel Archiver on Scientific Linux Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: some error about archive-viewer-14 Kay-Uwe Kasemir
