1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: striptool channel names
To: Ian A Smith <[email protected]>
Cc: TECHTALK <[email protected]>
Date: Thu, 2 Feb 2006 18:44:58 +0100 (MET)
		Hi Ian,
	It's depend from version of StripTool which you're using now.
In Argone web-page http://www.aps.anl.gov/epics/extensions/StripTool
you can download Strip_Tool_2.5.10.0, which can display
.DESC-field in legend-panel (right part of main screen)
I.e.
http://www-kryo.desy.de/documents/EPICS/DESY/General/Archiver/DesyStripTool/StripTool_New_Features.jpg
"Endcap II Druck 0-100mbar"
"TVC2SP1R3 Saugdruck RM-Trans"
"TVC2SP1R99 Anlagen-Ausgangsd"
"VC2ICP: PLC 0 connection"
"TVC2TP1R1 Saugdruck Leybold"
- is descriptions from IOC
	This extension of StripTool was developed and used here (DESY)
since  1998.
And as far as I know, it's currently supported by Argone (Ken Evans) as
well.
Albert Kagarmanov
MKS-2, DESY , Hamburg, Germany
> I've just started using striptool so the following is probably a newbie
> question:
> Striptool is only displaying the epics channel names for each line, it's
> not displaying the descriptions I have in each of the DESC fields of the
> records.  Is there something else I need to do the get the descriptions
> displayed on the graph?
> TIA
> Ian A Smith               Telephone: +44 (0) 131 668 8255
> Royal Observatory         Fax:       +44 (0) 131 668 8314
> Blackford Hill            Web:       http://www.roe.ac.uk/
> Edinburgh
> EH9 3HJ
> UK
Re: striptool channel names Ian A Smith
Prev: striptool channel names Ian A Smith
Next: Re: Cost effective solution for monitoring a large number of temperatures Josh Stein
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: striptool channel names Ian A Smith
