On Tuesday 31 January 2006 21:42, Andrew Johnson wrote:
> Michael Abbott wrote:
> >>> Of course this means that callocMustSucceed and mallocMustSucceed
> >>> can return a NULL pointer, which they currently never do.....
> >> That's the dilemma. I thought about that but I believe requesting
> >> zero-sized memory and subsequent de-referencing the return value
> >> can be considered a programming error. Otherwise, I can't see how
> >> to avoid a memory leak.
> > Makes sense to me. After all, what can you legally do with
> > char * x = malloc(0);
> I understand that position, however I really don't like it.
> The ?allocMustSucceed() routines were always a bit of a hack to avoid
> having to check the return value from ?alloc. They are only called
> in dbStaticLib and the IOC startup code in places where if you run
> out of memory there's no way you're going to be able to recover and
> still bring up the IOC, so the only thing you can do is bail out.
> They do that by printing an error message and suspending the task,
> thus ensuring that the caller never gets a chance to continue
> processing. The task suspend is to allow a developer to do a
> back-trace on the task that failed and thus find the rogue code, in
> the event that the problem is being caused by a bug rather than a
> lack of RAM.
One could argue that the same reasoning applies to all other kinds of
start-up code that gets executed more or less immediately after IOC
boot, e.g. in record and device supports init and init_record routines.
An out-of-memory situation here invariably means the IOC is overloaded
and obviously /cannot/ run as the developer planned.
Ben
- RE: callocMustSucceed error handling model Jeff Hill
- mallocMustSucceed( 0 ) non-portable Till Straumann
- Re: mallocMustSucceed( 0 ) non-portable Michael Abbott
- Re: mallocMustSucceed( 0 ) non-portable Andrew Johnson
Re: how to determine record type given pointer to a record Andrew Johnson
<2006>
<2006>
