1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: enhanced seq record
To: EPICS tech-talk <[email protected]>
Date: Mon, 30 Jan 2006 14:16:32 -0500
>>> On 1/30/2006 at 12:16:55 +0100, Luedeke Andreas wrote:
  > Of course the same can be done already with "calcout" chains.  But a
  > single record to control a sequence would simplify matters.
The calcout record is also one of the largest because it has all the calc
code in it, thus being very inefficient if you don't actually need to calc
anything.
I use seq or simple soft output records instead of calcout wherever
possible for that reason.
Brian McAllister                                   Senior Software Engineer
[email protected]                      Bates Research & Engineering Center
(617) 253-9537                                                Middleton, MA
Re: enhanced seq record Luedeke Andreas
Prev: Re: enhanced seq record Brian McAllister
Next: RE: enhanced seq record Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: enhanced seq record Luedeke Andreas
Next: Re: enhanced seq record Benjamin Franksen
